painting an let block which bits shouldnt be painted
Results 1 to 7 of 7
Thread: painting an let block which bits shouldnt be painted
    Oct 2003
    england
    about to paint my let block, i have stripped it bare, are there any areas that should not be painted, eg where the crank sensor seats or where the the dip stick tube sits or can i just paint the whole block
    Sep 2005
    Wisbech
    BMW 320d SE Omega Elite
    Re: painting an let block which bits shouldnt be painted
    Would avoid where the gearbox bolts to as that will affect earthing if your engine earth is attached to the gearbox.
    Knock, crank sensor mating surface, dip stick hole, oil pump matching surface.
    MIGClub Member elongmoss's Avatar
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    Easy any mating surfaces should be kept nice and clean and paint free for when it all goes back together
    If at first you dont succeed... CHEAT!
    Oct 2003
    england
    So crank and knock sensor area,was more concerned about the dip stick surface as a large gasket sits here,so leave this bare metal and where gearbox mates,Im using. por-15 with its own tech primer and once that sticks it isn't coming of easy
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    [QUOTEIm using. por-15 with its own tech primer and once that sticks it isn't coming of easy ][/QUOTE]
    But if any oil gets under it and it will in time! then you will have a right headache stripping it down and cleaning them up again. Trust me been there
    Oct 2003
    england
    Isn't it suppose to be oil resistant,normally the oil gets under if it hasnt been preped well
