difficult to remove speedo console??
Results 1 to 12 of 12
Thread: difficult to remove speedo console??
    Apr 2002
    Singapore
    MK3 Astra GSI 16V
    how difficult it is to remove speedo console (entire speedo, tacho, fuel gauge area) ??
    theres this fecking irrtating rattle that seems to be coming from the driver's A pillar......and the sounds seem to be coming from behind the dashboard
    i was thinking, remove the console, fiddle with hands and see which part stops the sound ........
    I've shoved paper, pressed, knocked, kicked (just kidding)lmao areas and the sound still persists!!!
    Control is nothing without Power.........
    Aug 2002
    In a v-big house in the country
    Mk3 1.8 16V Astra Sport
    I'm not sure what your rattle is but look at all the things that you'd never think it would be.
    I had a rattle in the back of my car, sounded like something in the boot somewhere but it turned out to be the bootlid itself!!!
    Of all the things i've lost,
    I miss my mind the most.....
    UK
    Cav turbo and XJR
    The rattle comes as standard equipment on the astra.
    Apr 2002
    Singapore
    MK3 Astra GSI 16V
    lmao lmao and i'm gonna get it removed!!
    are these really that badly built??
    The rattle i get is only audible when idling (not all the time too).
    Apr 2002
    Singapore
    MK3 Astra GSI 16V
    so what needs to be removed to get the whole console out??
    I know the steering column and black frame needs to be out, but what else??
    Mar 2001
    Torquay
    LC 20VT
    erm no it dont mate.
    remove the steering column shrouds
    remove the shroud in front of the clocks
    undo the screws holding the speedo to the dash
    put your hand behind the back ,and disconnect the speed cable,and the two power plugs.
    Take of your wheel if you can gives you more room,as the column aint adjustable.
    Apr 2002
    Liverpool
    Astra TD 1996 P
    be carefull with the speedo cable tho - its a tight fit !! if possible wear gloves otherwise ul end up with lovely cuts an slices round the back of ur hands.
    Apr 2002
    Singapore
    MK3 Astra GSI 16V
    clocks??? what clocks??
    which are the screws holding the speedo to the dash?? i only see those 3 screws holding the the plastic lens to the speedo console. I removed these, only the lens can be taken out.
    how messy are the power plugs and the speed cable?? is it an entagled mess or something a novice can handle??
    I'm afraid the cable/power plugs might drop backwards into the lower dash area
    May 2002
    There are 3 screws (1 upper & 2 lower) that hold the whole clock display to the dash. Once these are removed, unclip the speedo cable and power plugs and then twist out the clocks (if steering wheel still fitted). The wiring behind my dash was really neat & simple and its very unlikely anything will drop. The cabling kind of just stays there and don't move.
    Once you've done this once, its a piece of p*ss next time round. Should only take 10mins max.
    Hope this helps.
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    No cable in mine
    All lectric Just the two plugs
    Apr 2002
    Singapore
    MK3 Astra GSI 16V
    how does the speedo cable and power plugs unclip?? is it a snap on type?? or i've gotta pull back some kinda catch or what??
    Mar 2001
    Torquay
    LC 20VT
    The power plugs have clips that you push down ie compress towards the connector.
    The speedo one is a spring loaded type that pushes toward the clocks and same time pull the cable towards the engine.
