Advise on fitting bolt in rollcage wanted
Results 1 to 13 of 13
Thread: Advise on fitting bolt in rollcage wanted
    Nov 2009
    cheshunt, north london
    like its stolen, nova
    Ok I have a full rollcage for my nova and want to know how it needs to be fitted, it's a bolt in cage, so is it just a case of drilling holes in floor and bolting it down or do I have to do anything else? Want it to be fitted properly and safely which is why I'm asking
    Dec 2009
    birmingham
    astra 1.8 gsi/2.0xe
    Re: Advise on fitting bolt in rollcage wanted
    you may find that once it is all put together in the car mate it will sit of the floor/arches in places so you may have to use packers weld the packers to cage were needed then bolt packer to floor hope this helps a little
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Follow the guidelines in the MSA bluebook
    Nov 2009
    Where do I find the guidelines mate? Have been told to get some metal to have under the car with the bolts going through the cage floor and arches then the metal under the car
    Jun 2002
    Wrectum
    in the MSA Blue Book
    Nov 2009
    Ok, where do I get that from?
    Jun 2002
    Wrectum
    Yes you need floor and arch plates, as the std metal isn't very thick.
    Nov 2009
    Thanks benn, does it need just one plate or two, one inside the car and one under it?
    Normally just a nice thick on on the inside of the car.
    Nov 2009
    Ok thanks, I have seen in a different site something about it and it says 3 mil thick, does that sound right
    Anything thicker than Factor metal and your ok i'd think.
    Jun 2002
    Wrectum
    Quote Originally Posted by novaredtop View Post
    If you'd read the link I gave you
    Minimum mountings are:
    1 for each leg of the main or lateral rollbar.
    1 for each leg of the front rollbar.
    1 for each backstay (see 1.3.3).
    Each mounting foot of the front, main and lateral
    rollbars must include a reinforcement plate of a
    material of at least the same thickness as the wall
    of the tube to which it is being welded
    (minimum 3mm).
    Each mounting foot must be attached by at least three
    bolts, minimum M8 150 grade 8.8, on a steel
    reinforcement plate at least 3mm thick and of at least
    120cm2
    area which is welded to the bodyshell (see
    drawings K13 to K18). The mounting feet may
    alternatively be welded direct to the reinforcement
    plate. This does not apply to backstays (see 1.3.3)
