can't get momo steering of cav gsi
Results 1 to 9 of 9
Thread: can't get momo steering of cav gsi
    Dec 2008
    birmingham
    Vectra SRI
    I've brought a oem steering wheel and can't get the momo one off, I've taken the bolt of but its just to stiff
    Aug 2004
    South Yorkshire
    Track GTE Champion
    Re: can't get momo steering of cav gsi
    See if you can borrow some pullers, save yourself a lot of hassle...last time I tried it without them I lost my rag and ended up having to buy a new windscreen
    Dec 2008
    birmingham
    Vectra SRI
    ill try borrowing some, and my windscreens broken anyway lol
    MIGClub Member Corsa_LET's Avatar
    Sep 2011
    Nottingham
    Astra z20let sleeper
    Hammer time!
    pie
    pie is online now
    May 2009
    blackwood
    Cavalier GSI 4x4
    steering wheel puller?
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Have a look at the boss and see if you have two oval holes either side of where the column goes through (look at your OEM wheel to compare). If these are present you'll need to use a GM steering wheel puller to get it off. You can pick them up on ebay for around a tenner if you can't find one to borrow. Halfords sometimes have Laser ones in stock.
    Mar 2004
    newcastle upon tyne
    WRX
    Quote Originally Posted by Corsa_LET View Post
    Hammer time!
    Don't use a hammer. Collapse-able column.
    Buy a puller, you'll not break your nose when the wheel comes off the column.
    Nov 2008
    Llanrwst
    cav mk3
    wd40 and pull?
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    if relying on brute strength and/or violence, leave the nut on a few threads so you don't disfigure yourself.
