astra passenger rear door stuck
Results 1 to 4 of 4
Thread: astra passenger rear door stuck
    Nov 2011
    hello, the rear door on my astra mk4 1999 1.6 club wont open from inside or out! all the other doors work fine? do you guys have any tips of atlest geting the door open so i can get the door card off and have a look?
    cheers
    adam
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Re: astra passenger rear door stuck
    It might be the deadlock has activated on the door and got stuck - you can still pull the locks up on my MK4 with the deadlock on but you can't open the door.
    Sounds like you might need to pry the doorcard off from inside and maybe get a replacement from the scrappie if you damage it
    Nov 2011
    thanks for the reply. i tryed pulling the dead lock up alought nothing has happened door still wont open from the in side or out sounds like its going to be a pain of a job to do
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    Used to happen to the drivers door on my caddy van, even when i was inside! it was a right pain in the ass.
    door card should come off with a bit of force...
