Light up grab handles
Results 1 to 21 of 21
Thread: Light up grab handles
    Dec 2001
    Southampton/Reading
    No longer The Pheonix
    Do these bolt straight in to a gsi or do i need to make any modifications? I know some you need to cut away some of the metal to make them fit, but wondered if the gsi may already be prepared for them.
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD Cav Turbo
    I fitted some to my 94 hatch a while back, they came from a 92 GSi & were a straight fit.
    The wiring plug should be theer already, taped up next to the ariel.
    3.0 V6 Mk3 Cav - Saab B308I, F28, Speedlines, Wilwoods
    Cav 16v Turbo - T34, water inj, 26psi, F28, LSD, Speedlines
    04 Monaro 5.7 CV8 - Pedders Suspension, Wortec Catback
    Dec 2001
    Southampton/Reading
    I read on Cavweb that from 91 onwards the holes and wiring were there, but dont know if thats just the models under the GSI. Mines a 1990
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD Cav Turbo
    Its easy to check if the plugs there, pull the trim of around the boot light & it should be in there next to the ariel motor, there is 1 Red wire, 1 brown & 1 grey.
    Dec 2001
    Southampton/Reading
    Cheers i'll take a look for that later
    UK
    Cav turbo and XJR
    A 1990 GSi requires metal cutting.
    What year/plate is yours ?
    Dec 2001
    Southampton/Reading
    G
    lee may
    Guest
    Its easy, Put the suround on and mark/cut the roof lining away then chain drill the mark and file the meteal flat.
    Its not hard just fiddly
    Dec 2001
    Southampton/Reading
    Excuse my lack of brains but what is chain drill?
    lee may
    Guest
    Drill lots of little holes in a line
    Dec 2001
    Southampton/Reading
    Doh Is it easy to slip and phuck up big time? I dont wanna be drilling through my roof
    lee may
    Guest
    Its easy. Its double skined there anyway
    Oct 2002
    Norfolk
    16v Astra GTE 1990
    Do these fit on mkII astra?
    Aug 2002
    So the gsi (cav) had roof grab handles with lights in them? Mine doesn't?
    lee may
    Guest
    Some late cav gsi's had them and I think all cav turbos had them.
    Aug 2002
    sounds nice,any idea where I can see a picture of them fitted?
    Do they come on with the door lights?
    lee may
    Guest
    They are wired to the interior light and have a 3 way switch on them.
    Off, on and on with the interior light/door lights.
    Aug 2002
    I like it!!
    (fitted on rear handles only?)
    I HAVE to get a set now!!
    Oct 2002
    Willenhall
    Vectra V6 CDX
    Got a Mk2 Astra SXi and it's as dark as death in the back - I'm sure there's still a kebab in there from last month !!
    Anybody know if I could put them straight in or would there be a bit of roof-cutting which I suspect there will ?
    For info - fitted some straight into the back of a face-lift Cav '92 GLS with no cutting but had to run some wiring !)
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    Being only 5 Watts they don't shed much light in the back!!
    Don't expect to be able to read by it!!
    Oct 2002
    Willenhall
    Vectra V6 CDX
    I'm not too bothered just as long as it's not pitch black when you open the doors really but do you know if they would fit straight in or would I need to do some cutting ?
