Side repeaters
Results 1 to 4 of 4
Thread: Side repeaters
    Aug 2002
    Manchester
    92 Astra SRi with 5
    Side repeaters
    I got a set of oval side repaters yesterday for my mk3 astra (series 1). The problem is that the hole in the wing is a diferent shape and size to the new repeater. The hole is too small.
    Has anyone else fitted the series 2 (oval) repeater to the earlier astra and how did you do it?
    I've thought about trimming the plastic on the back of the repeater away and fixing it with some kind of sealer (like silicon sealer). Not sure how secure this would be though.
    Anyone help?
    Dec 2001
    Cleethorpes
    Cav 130/ Astra VXR
    I went to the trouble of cutting the wings so they would clip in.I know the easy alternative is to break the clips off ,and silicone or just double sided tape them in!. The bulb holders may be different as well so watch for that one
    Sep 2001
    Glasgow Area-ish
    EVO VI & GTE 16
    triming and using silicon sealants how most people do it
    Never get an EGG credit card they do nothing to protect you if your card is subject to Fraud!!!!!!!!!!!!!!!!!!!
    Apr 2002
    Cornwall
    Vauxhalls
    trim n glue. I've replaced your oval repeaters for mk4's.
    fit perfectly if u turn em around the other way, clip in no problem without any trimming.
    good luck
