Re: chevette, which wheels?
shuvit are 4x100 aren't they, not 4x4"?
yes there 4x100 and i think there 13" standard. i keep seeing ones with superlites on but i cant for the life of me find any for that fitment there all 4x108 " ford fitment "
I've a literal shed full (well, about half) of E30 'bottle cap' alloys with a selection of tyre types, for the Chevette. They're a 40 offset, 6x14 rim and may need a 5mm spacer on the front to stop rubbing on the damper at full droop with 195's, 185s cleared, just. Depends on the damper, though, as some don't drop far enough to be a problem.
they don't worry about centre bores down here, so can't say for sure they're the same - certainly not smaller...
Stock Chevette wheel is 37 offset, 5x13.
Other options are some Hondas, isuzus, Toyotas, Nissans, etc - but nNOT all - check and also offsets for the FWD cars may be a problem - also check.
mini wheels fit! pcd off 4 inch so like 101.somthing mm get a set off 13x8 alley cats on
Using 4" (101.6mm) pcd is stupid and dangerous - an excellent way to smap studs and loose a wheel.
However, you could use a spacing adaptor if you wanted - for an 8" rim, you really need a zero offset - widened restyles with, IIRC, 175/50 tyres are quite popular down here. I don't much care for the look in general, but it can look really good on lowered wagons.
You may want to have a look here - The New Zealand GM T-Car Club - Home - it's slow to load so give it time.
If you're looking to tweak the 1256 engine, check out my earlier posts there.
