wheels for Cav turbo
Results 1 to 15 of 15
Thread: wheels for Cav turbo
    Sep 2008
    scotland
    New to looking at details of alloy wheels fitted to cars lmao
    basically 2153518 on cav turbo
    8x18 with offset 30/35
    any rubbing issues or running issues
    looking to put some better looking wheels on the car and lowet slightly
    been looking on net and offset according to sites is 35 to 45
    but originals are 49!
    Help as i only got so long to sort this and order the wheels,shed load of money if i
    get it wrong
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Re: wheels
    Online Wheel & Tyre Fitment calculator. Offset and Tyre Stretch
    Take measurements of the clearance you have with the current wheels and work it out from there. 49 is the best offset for your suspension geometry but you can fit lower. Usually down to 40 has little effect on normal driving.
    May 2001
    South Wales
    Nippy Cav Turbo
    Re: wheels
    to run wheels on ur cav turbo they need to be pcd 5x110 and offset et40-49...
    if u go lower than et40 i.e. 35 36 38 etc....u will leave ur arches behind u as u drive off cause ur wheels will stick out further than the arch! U can run 8j wide alloys on the cav but tbh u would be better off running 225x40x18 tyres (in doing so u will need arch mods i.e. roll the arch lips) cause 8j alloys are wider than the norm which would be 7.0 or 7.5j and u could end up cracking ur alloys merely cause the tyre width aint covering the wheel to protect. I found this out hard way
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Re: wheels for Cav turbo
    Title changed and moved to correct section.
    They're there, in their room.
    Sep 2008
    scotland
    Just sounds like to much messing about to me,was hoping i could fit a nice set of 18,s without any mod work!!
    well just found same wheels now with pcd of 112 and offset of et50
    surely about as close you can get!
    Nov 2008
    Luton
    Smokey Saloon
    you should buy these , if they were nt so far away i would consider them for my mk5 astra
    Vauxhall Fitment techno magnesio multispoke 18" Alloys | eBay
    Sep 2008
    scotland
    dam pc link wont work.. lol
    really looking for oz wheels,mind you might change mind when see the above!
    cheers pal
    i take it you live some distance from them
    Nov 2008
    Luton
    Smokey Saloon
    yeah 315 miles is a bit too far plus just had new rubbers on the factory wheels
    ebay item number 280710610495
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    my cav on 18s on 60mm drop
    techno's
    kahns
    Sep 2008
    scotland
    Nice wheels look smart... Any probs rubbing wise. Im hopefully getting 215/35/18 8/18 offset 50 should be ok? lowered no more than 35m
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    mine 215 35 18s on both my sets no rubbing at all they
    the technos are et49 n kahns et45
    sgould be alright on 35mm drop
    Sep 2008
    scotland
    Wot even offset 50 That makes it inward more?
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    it would be close to the shock may even touche the shock
    id stick et45-48
    Sep 2008
    scotland
    Just found some other alloys team dynamics 7.5 18 correct stud pattern offset of 45 im running 7.5 18 with offset 44 at mo no issues
    should be fine 2153518 then
    Sep 2008
    scotland
    Correct above im on Gsi 17 inch wheels at mo
