Bubbled paint work ?
Results 1 to 6 of 6
Thread: Bubbled paint work ?
    Sep 2001
    UK
    GSXR600&ImprezaTurbo
    Some of my paintwork has bubbles slightly near the rear arch, i`ve sorted the rust underneath , but these bubbles are solid, i thought they would "burst" when i applied pressure to them, then i would have sorted them out, but when i applied pressure, they are solid, didnt crack up or ought ?
    Is this the metal flexed due to the rust ?
    Cheers.........
    Glory Glory Man Utd..........The Red Devil is Gaining Strength.............
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Nope, it's rust and water that's got in underneath the filler. Basically the filler has lifted away from the paint. Looks like it wasn't repaired or had the rust fully removed / metal protection behind it.
    If you were to chip off the bubble, you'd find that the metal work behind would be weeping with rust.
    Jan 2002
    Nr. Ipswich, Suffolk
    Transit Connect & Cav GSi
    I have experienced this with a car before.
    Again it was on a rear arch (A Vauxhall to, so no great suprise there). When I questioned the bosyshop about it, this is what they told me and make of it what you like:-
    'Water gets between the two panels (rear arches are double skinned). No matter how long they leave the car in the oven, it isn't possible to get it all out. The filler on the other hand does tend to draw the water out, thus bubbling under the paint.'
    Sep 2002
    Here
    Cav Turbo, Saab 93, A2
    I found a bubble on the rear arch of mine the otherday, I pushed it and it sprayed water out
    Oh well, a Vaux owners work is never done lmao
    Oct 2002
    warrington
    Toledo, polo & 20XE
    Angry
    my G reg mk2 astra is the same
    thinkin of a ful respray cos 3 of the arches r bubblin
    rear r well bad.and thers a huge corner chip on the front bumper
    Nov 2002
    Southport
    1991 Cavalier GSI 2000
    Wink Me too is it a problem on GSI's
    I have got a Cav GSI and its done a very similar thing on the back arches, does anyone know who is the best company to get rust out and respray them
    Thanks
    JV
