Results 1 to 14 of 14
Thread: sideskirts
    Oct 2002
    fleet,hampshire
    astra mk2 16v
    sideskirts
    iv just got some animal sideskirts from autofashion, had to wait 2 bloody months!! but well worth the wait, anyway, how has eveyone else attached thiers? iv been told to use sikaflex but i wanna fill over it to smooth it in to the body work, i was thinkin no more nails or mashtik(or howerva u spell it) but i cant see this bieng strong enough to hold em, as thiers onlt gonna be 2 screw eithier side(nospace for any in the door steps!) help!!
    the k stands for kiran
    Joy
    Joy is online now
    Sep 2001
    Devon
    2WD Cav Turbo
    Sikaflex is the stuff to use, make sure its 227 (the non-sagging stuff) & it can be used to smooth the join. This is how I smoothed the join of my rear apron to rear bumper.
    3.0 V6 Mk3 Cav - Saab B308I, F28, Speedlines, Wilwoods
    Cav 16v Turbo - T34, water inj, 26psi, F28, LSD, Speedlines
    2004 Monaro CV8 - Pedders Suspension
    Oct 2002
    fleet,hampshire
    astra mk2 16v
    the gaps about 5mm-1cm so in places the skirtsdont actually touch the body work, will it still hold? and can it b sprayed over? did u use it 3 bond or smooth? coz i need it to bond! i just wanna make sure b4 i f**k it up!
    Joy
    Joy is online now
    Sep 2001
    Devon
    2WD Cav Turbo
    I used it to bond & smooth though the gap I had was only about 2mm.
    Oct 2002
    fleet,hampshire
    astra mk2 16v
    hmmm guess il just have to see what they,v got, iv been told spoiler adhesive would be good, ne1 elsegot any ideas?
    Joy
    Joy is online now
    Sep 2001
    Devon
    2WD Cav Turbo
    A 10mm gap is rather excessive, is there any way you can smooth the joining edge off to leave an even gap the whole length.
    Mar 2001
    Essex
    Cav V6
    I just put on my side skirts this weekend actually!
    Everyone recommended sikoflex to me so I bought some.
    Well, at first, after I spend ages slapping glue all over the place, I held it on but wasn't convinced it'd be strong enough to hold it!!! I put a jack under it to hold it in place and various bits of wood. It was an ar$e in the start cause it wasn't staying where I wanted it to - but in the end got it held there.
    It took about 5 hours to dry and well, hell I'm impressed......it flexes when you try move it (guess that's why it's called sikoflex) but it's well rigid!!
    I think you should go with that - I'm well impressed and will be using that to stick on spoilers and the door panels!
    I got my sikoflex from partco for a tenner!
    m
    WWW.MARKLESTERMUSIC.COM
    Come Read This Diary
    "Lay on your back in the sun, and feel the breeze"
    Oct 2002
    fleet,hampshire
    astra mk2 16v
    i went tp partco this mornin and they only had silkaflex 221, so i got some tiger seal, its supposed to be good, just bout to find out! il let ya know it it turns out.
    Mar 2001
    Essex
    Cav V6
    If partco only sell 221 what's the difference between that and the 228 then????
    my kits not gonna fall off is it?????
    Oct 2002
    fleet,hampshire
    astra mk2 16v
    i shouldnt think so, i just got told 227 ws the stuff to use, as u can see above, i wouldnt of thought its that dif! well hope not 4 ur sake!
    Joy
    Joy is online now
    Sep 2001
    Devon
    2WD Cav Turbo
    I don`t think theres much difference between the 221/227.
    Aug 2000
    Harlow, Essex
    Calibra Redtop 16v
    I used 15 minute epoxy resin and silicone sealant to fit my skirts then i fibreglassed/filled on the top edge to smooth it into the body. As for all this use of jacks and bits of wood to hold it in place, don't bother if ur gonna smooth the top edge in with filler anyway, just whack a few self tapping metal screws along the top edge with some epoxy resin behind it to bond it to the sill. Then just remove the screws and fill and smooth over the holes.
    Andy
    Oct 2002
    fleet,hampshire
    astra mk2 16v
    job done! used tiger seal, dunno how its gonna turn out, i just used maskin tape and my leg to hold it, the only thing im worried bout is that its still tacky, will it always stay that way? if so should i fill over it? coz i can see it gettin sprayed then someone pokin it and it all been a mess!! what should i do? advice anyone?
    Oct 2002
    fleet,hampshire
    astra mk2 16v
    job done! used tiger seal, dunno how its gonna turn out, i just used maskin tape and my leg to hold it, the only thing im worried bout is that its still tacky, will it always stay that way? if so should i fill over it? coz i can see it gettin sprayed then someone pokin it and it all been a mess!! what should i do astra? anyone got any helpful advice?
