Wheres the best place to get replacement panels from?
I'm after both rear arches with the inner panels. Vaux want nearly £500![]()
Cheers mate![]()
you used them before? The panels as good as vaux?
nope thay are junk they look like they will fit but don't
You had some panels off them Gaz?
Do you know of anywhere else?
Yep front wings, just bit the bullet and bought vaux ones, they fitted first time
the imperial: the joins wern't even a bit out they were hugly out at least 10mm out at the back near the doors
sorry keep your ear to the ground ive just got a new tailgate for £60 rather than the £180 vaux wanted
are you after arches and things or doors? if you want bodypanels ei arches try U.S.E or spares people, im not to sure if they'v got places in manchester but if they do, thier cheap! i got two front arches at bout £60 for both and a whole back end, arches and lower valence for bout £160 hope this helps
the k stands for kiran
