mounting tv screen
just changed my cav at the weekend and im looking for a way to mount my centurion 5.6" screen on the dash without having the mounting on show when the screen is out and without putting any screws in the dash!
Is it an in dash one (Stereo style) or just a screen that needs to be mounted?
it needs to be mounted! on my last cav i had it stuck on the dash, ok if the screen is on but looked a mess when not in!
Will it fit where the ashtray is? Thats where I was going to put mine when I get it.
Mount it far enough back so the cover can still go over it and then not be seen.
i cant put it there its a v6 so ive got switches there asnd the switch for the sound from the tv! any one know of a clamp for the vents or the space above the glove box? ive put the wires into the glove box so when the screen is out the wires just go back there!
got it done now!
got my dad to cut a strip of metal out about 2 1/2" wide and 13" long, i mounted it in the space above the glove box! bent it to shape to turn up over the dash, then took the glove box out and drilled a hole for a bolt! drilled the bracket, put the bolt into the plastic and put a nut on to lock it in place, then i use a wing nut to fix the bracket so when not in use there is nothing to be seen!
oh just for that posh look a touch of gold paint!
i will put a photo up! thats when one of you kind people let me know how to do it!
i made a braket on the center consol......
and used silicon to fix it on with, so when/if it comes to a change i can remove it without any holes. i anm planing a roof pod in the very near future + some other bits and pieces
gav.
i will put a photo up! thats when one of you kind people let me know how to do it! Chants... PHOTO...PHOTO...PHOTO...
Email it to me mate, I'll sort it out !
