Help With Boot Build
Results 1 to 13 of 13
Thread: Help With Boot Build
    MIGWeb User selblock's Avatar
    Oct 2002
    Newquay, Cornwall
    Prodrive Astra SRi
    have just sound deadend my boot, worked a treat, no more vibrations.
    what is the best way to make a floor, i tried mdf but its quite **** as 2 get it in i needed to cut it in half and i saggs, i want a flat floor, then i want to mount my sub and amp somewhere but dont know how to,
    please help, astra mark3 boots are ****!
    look at my site (in my sig) and tell me what you think also
    May 2002
    Tell me about it mate, boot floor on a Mk3 is pants. Last time i did an install it was just by trial and error. MDF width of boot split into two down the middle, then numerous blocks underneath to get it level. It ended up looking ok and the split down the middle was hardly noticeable. Why not build the floor up on blocks and just sink the amp beneath the floor? By the time you've got the floor level there should be plenty of room to sink the amp.
    When i start my new install at the weekend im considering mounting the amp vertically on one side (still sunk into mdf) in the hope that it may be a bit easier.
    Oct 2002
    Newquay, Cornwall
    Prodrive Astra SRi
    yea mate, im trying to figure a way to get the floo level so i can build it up straight, i will have a poke around but its gonna be hard,
    anyone else have any gen on this
    midands
    astra 888 (280/320)
    when i did mine i used a 10mm sheet cut in the middle, screwed to the boot floor with a hole for the spare wheel - then i used 4x4 timber to build a frame so i could make a false floor - whole boot took me 24 hours from start to fully finished inc wiring - it was my first time and was easy
    Oct 2002
    Newquay, Cornwall
    Prodrive Astra SRi
    st200 rich have you got a pic?
    May 2002
    st200 rich, how did you overcome the problem of the uneven boot floor? Did you just bolt the mdf down at whatever angle it sat at or did u use blocks to raise certain sections?
    Im just intreaged as im sure there's an easier way than what i did cos it took me about 20 hrs in total. It was my 1st ever install mind.
    midands
    astra 888 (280/320)
    yeah - i remember i did use a block of wood to get it level on some parts - i do have a pic but not of the actual underside - just the final finished job
    Oct 2002
    Newquay, Cornwall
    Prodrive Astra SRi
    post the pic anyways mate
    evo
    evo is offline
    Oct 2002
    manchester
    astra coupe SE1
    Can any 1 tell me if i will have the same problem of sagging with the mk4 astra or is it just with the mk3, coz im getting my boot sorted out with a sub and amp on monday and want to know if i will have any problems after they r put in.
    May 2002
    Northampton
    Polo Variant
    Boot build
    I bulit my false floor in my MK4 Astra out of two layers of 18mm thick MDF, this is very sturdy and doesnt flex at all. Then made cutouts in the top layer for my amp and box so that they are recessed and are secure.
    Family Wagon
    Somerset
    2006 Suzuki GSXR 750
    build a frame for everything to sit on.
    -VXRacing-
    12.1 @ 123mph 1/4 Mile
    May 2002
    Northampton
    Polo Variant
    OK that puts mine to shame
    Family Wagon
    Somerset
    Rob Fairbrother built the install and Phil (AstraSport) did the LEDs which will be put into the enclosure later this week.
    -VXRacing-
