fitting m3 mirrors
Results 1 to 6 of 6
Thread: fitting m3 mirrors
    Oct 2002
    wigan
    corsa
    fitting m3 mirrors
    this might sound like im a bit thick but im new to the modding business, so does anyone know hot to fit them to a corsa. Ive got the base plates but i just want some advice first before i take the wrong thing off and completely knacker the door. Help!
    Feb 2002
    North London
    EP3 Civic Type-R
    Fitted them myself on my Mk3 astra, cant be much different on a corsa, its pretty easy, just some clips on the inside reveal the screws to the mirrors, the mirrors come straight off, had a little trouble gettin them flush to the window thou
    Keeping it Real
    - MigWeb's Undisputed Street Fighter III 3S Champion -
    Oct 2002
    wigan
    corsa
    Come on, nobody fitted these to a corsa?
    Jun 2002
    Home of the Vauxhall
    Astra VXR
    Take the inside trim off your factory mirrors. If they are electric, the trim slides up and pulls forward. If you have manual mirrors, I think you will need to remove the adjusting lever first.
    When the trim is off, you will see the mirror is held on with 3 screws, undo these and the complete unit is removed.
    To fit the new ones, just hold it in place while doing up the 3 screws. It is a straight forward swap over job and will literally only take a few mins each side.
    Oct 2002
    wigan
    corsa
    when i got home from work today my dad had already fitted them, but he said he lever inside doesnt move the mirror, anyone got any idea whats happening?
    Jun 2002
    Astra VXR
    I fitted electric mirrors to mine so I'm not sure about the manual ones. I don't think the original levers will work. I think you have to lean out the window, and physicaly move the glass by hand. Don't quote me on that though.
