Will Audi wheels Fit Vectra?? They are the same stud pattern
Results 1 to 2 of 2
Thread: Will Audi wheels Fit Vectra?? They are the same stud pattern
    Jun 2010
    The North
    Cav XE Motorsport + VAG
    they are 235/45/17 and offset are et 45
    thanks
    Turbo Lag Is Utter Gash
    Jan 2005
    Edinburgh
    Re: Will Audi wheels Fit Vectra?? They are the same stud pattern
    Vectra B PCD is 5/110 and centre bose is 56.6mm
    Audi PCD's are 5/100 or 5/112 and centre bore is 57.1mm so you would need reduction bolts.
    205/45, 215/40, 215/45 and 235/40 are all within the correct tolerances so 235/45-17, having a greater rolling radius, would involve a slight reduction in acceleration time.
    ET45 is fine but if these are original Audi wheels they will probably use radius bolts, rather than tapered
