team dynamics wheels on corsa
Just bought some wheels off a mate, not sure which model they are but they have a multi fitment stud pattern. Only problem is that the bore of the wheel doesnt seem the right size, is this safe to drive on? he said that he had them on a corsa before. Any help please?
Re: team dynamics wheels on corsa
they should fit aslong as the stud holes line up. you need to speek to your mate or go on ebay and get some spigot rings so they fit your hubs, like spacer so the wheels fit correctly. if you measure the inside diameter of your wheels and the diameter of the hub you can order the correct ones. theyre about £8 on ebay. if you dont use the spigot rings, your car will judder slightly when driving and eventually kill your wheel bearings
ok cheers mate, just found them on ebay, will order some tomorrow, thanks for the advice
