Results 1 to 5 of 5
Thread: GTE 16V Centre Console Removal
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    I've got the section out around the gearstick with the cassette holders in, but the bit under the handbrake will not budge. I've taken the single screw out from under the little blank. I assumed it just slides backwards like on a 8V, but mine will not move. Even tried using an improvised punch and whacking it backwards with a mallet, to the point I'm worried I'm going to break it.
    Am I missing something?
    They're there, in their room.
    Jan 2005
    North london
    astra gte 16v
    Re: GTE 16V Centre Console Removal
    im sure there are two screws eather side in the footwell and one behind the cassette case have to lift the gearstick gator and take the bit that holds the cassette cases that goes down to the gear stick.also did you get the one under the cloth thing between seats where you put your mobile lol hope this makes sence.
    used to undo this when i used to mess with my motion sensor on my clifford
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    I've got the cassette holder section out already. So you're saying I have to peel the carpet up in the little tray behind the handbrake to reach a screw underneath?
    Jan 2005
    North london
    astra gte 16v
    yea and its attached at the front on the sides of the footwell if there is any more think you have to take the heater panel to take it out.
    Jan 2005
    North london
    astra gte 16v
    been about 7 years since i have done it lol
