Results 1 to 5 of 5
Thread: digi dash in my corsa b
    Nov 2009
    Cumbria
    Corsa B 1.2 8v
    oryt people av got a 1.2 8v and lookin to buy a digi dash out ov a astra gte. the speedo is electric not cable driven, does any1 no wot to do with the transducers or how to get it to work properly am a bit confused on what i need or to do plz help cheers
    Nov 2009
    Cumbria
    Corsa B 1.2 8v
    Re: digi dash in my corsa b
    its all electric ie speedo clocks etc will it b ok to use or do i need to do anyfin to get it to work properly??
    Aug 2010
    alness
    astra van, calibra 16v
    hi bud, i did the same conversion in my nova, dont know how you will get a square cluster to fit the corsa round hole but the wiring is not to hard you NEED the sender from the gearbox to match the clocks for the speedo. then you run the wire from their to your dash as for the rest of the wires i cant remember the colouring but i would search for nova digi dash conversion you should find what you need to know.
    good luck
    Banned
    Feb 2010
    all the colours should match up colour fr colour. and digis take a lot of fh i took the clock surrounds of an old corsa and fibreglassed that to the front of a set of digis. took a lot of sanding and a few coats of satin black but it looked ok in the end
    Feb 2006
    Have a read through this, may help you a little CLICKY
