Anyone know anywhere in or near stoke on trent that will fit (And do a good job!) bonnet vents on a Mk3 Cav. They need to be painted too!
i took the sound profin stuff off from under the bonnet and there a re 5 large panels which i can cut out.
options are:-
1. sits right over the engine (further back in the middle)
2. the other option is to cut out 2 of either side of the center panel (long but thinner type of thing)
3. 2 at the front sort of like a mitsubishi evo style bonnet.
4. leave it alone.
5. do em all and keep the lump real cool.
gona have to give it some seroius thought as this could kill the look of the car if i do a wrong'un.![]()
gav.
RJ Automotive are in Cannock/Wallsal just of M6 junction 10 down the A5...they to far away??
::: Designed For All Astra Drivers - astraownersclub.com :::
spraynique is the best place in stoke.
the bodyshop i use is in rugby, but thats quite far.
spraynique: 01782262277
or
wg body repairs: 01782811112
spraynique arent cheap though. but i presume you just need the vents spraying?
normal quote for a bonnet is 100quid. (to be srapyed)
It will be good one day!
