Final Cav hatch GSi bumper theory...
Results 1 to 4 of 4
Thread: Final Cav hatch GSi bumper theory...
    Sep 2001
    Cavaliers Mk1 Mk2 and Mk3
    Right, since I was told on here that the GSi rear is just o cover over the standard bumper, I've done a little homework and theoretically...
    its possible to buy GSi rear bumper, take of cover, throw away backing for saloon, shorten GSi cover, and attach it to a standard hatch backing and bolt onto the car....
    Its a good plan, but knowing Vuaxhall it sounds to 'simple' to be possible...
    anyone able to shed light on it....?
    Cheers
    Mk1 Cavalier 2dr 1300 - Mk2 Cavalier SRi C20LET - Mk3 Cavalier SRi V6
    Jun 2002
    Barnstaple,N.Devon
    Vectra Supertouring
    Yes mate.It should clip on ok across the back,and if you cut the sides with care you can line up the standard clips to help hold the pieces together while you fix the bits back together.
    1997 VECTRA SUPERTOURING #0166
    2002 FONTERA 2.2 TDi
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Just take your old bumper and the Cav GSi rear bumper to a bumper specialists and get them to plastic weld it up. It'll look nice and won't crack.
    Jul 2000
    as simon says, plastic welding is good.
    do it yourself using offcuts of plastic, and a soldering iron
    BRB
