Results 1 to 4 of 4
Thread: Flushed boot help
    May 2009
    hull
    corsa 1.2
    Flushed boot help
    Ryt just bought a flushed boot put it on but wen I get it to sit flush I can move tho boot like the lock doesn't latch properly. Is there any way to adjust it so it sits ryt and locks properly with no play cheers
    May 2009
    hull
    corsa 1.2
    Re: Flushed boot help
    surely some must know if i can move summit like the latch or summit?
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Might help if you didn't spell right with with a 'y' in it!
    You can either adjust the latch or the rubbers.
    May 2009
    hull
    corsa 1.2
    ok so the latch on the boot can be adjusted how?
