Results 1 to 14 of 14
Thread: advice needed on wheels
    Mar 2010
    MK4 astra 'G'
    hi i have only just joined up but have used this forum loads in the past which has helped me out, so a big cheers for that
    today i got a puncture, so i changed the spare only to realise it is a 15" and all my wheels are 14". i have bought a set of alloys (5 split spoke original vauxhall) which are 16" but was only planning on changing them when the standard 14 inch steelies had worn out. but could i put two of the alloys on the back and the other steel wheels on the front. the front wheels are 185 60 14 (i am almost certain off the top of my head) and the alloys would be 205 50 16
    oh and i believe the offset was 5.5 original and 6 on the alloys
    sorry for such a essay :S i hope i have been clear enough
    MSG
    MSG is offline
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Re: advice needed on wheels
    I think you can as long as they are same on each axiel (spell) but you canot have different ones on the same axial apart from the emergency space saving spare wheel with speed and distance restriction.
    Dec 2001
    Southampton/Reading
    The Pheonix
    As MSG said. Your fine so long as the axle has matching ends, lol
    Mar 2010
    MK4 astra 'G'
    cheers im feeling safer now lol i was just a bit unsure because of the differnaces in width...and also when i do change all four will this make the speedo less accurate?
    Dec 2001
    Southampton/Reading
    The Pheonix
    You should be fine going from 14" to 16" on the grounds that the tyres will be lower profile. There will be little difference i would imagine.
    Mar 2010
    MK4 astra 'G'
    it will be going from 14 to 16's but still not more than a couple of % out though?
    Feb 2010
    Stranraer, Scotland
    Corsa B C20XE
    Good job you put the 16's on the back, I had a friend that couldn't work out why he was an idiot for putting the smaller wheels on the back. That was before it rained and he ended up on his roof!
    Dec 2001
    Southampton/Reading
    The Pheonix
    Quote Originally Posted by Steve_Gers View Post
    Please explain more. Maybe its me being thick but i cant see how the rain would cause a car to flip over. Maybe he just drives likes a ****?
    Feb 2010
    Stranraer, Scotland
    Corsa B C20XE
    Yeah his dodgy driving is part of it but he had 13" skinny steelies on the back and grippy 16" alloys on the front. With the added help of the rain making the road slippy he tried going round a corner at his usual pace and as you would expect the steel wheels on the back made the car go sideways which he couldn't control.
    Mar 2010
    MK4 astra 'G'
    ^possibly less downforce from the higher front end was 2% and his driving the rest, but cheers for the top quality and speedy responses guys!
    Feb 2010
    Stranraer, Scotland
    Corsa B C20XE
    How big a puncture is it? McConechey's where I live will fix a puncture and balance the wheel for a fiver
    "If in doubt, FLAT OUT!"
    Colin McRae 1968-2007
    PSN - steve-gers1989
    Dec 2001
    Southampton/Reading
    The Pheonix
    Mar 2010
    MK4 astra 'G'
    that is a cracking deal but the tyre is on the limit with the tread so its not really worth it, and i had bought the alloys last month because i've wanted that style for a while...so its a good excuse to get them on and not lose out on the good tread on the other tyres
    Feb 2010
    Stranraer, Scotland
    Corsa B C20XE
    Not as good as 4 barely part worn Continental EcoContact tyres with 7-8mm tread left for 40 quid and that includes buying them and having them fitted + balanced. That was for my old corsa c though 175/70/13. Will be a bit more harsh on the wallet getting 205/40/16 on the new corsa's Irmschers
