Nova Front Indicators
On the mk2 nova the front indicators are white, with a orange insert thingy & a clear bulb. Do the after market ones have this as well?
And also is it similar on the reversing light?
i have aftermarket front indecators and yes they do have a orange filter in them but i have expermiented with my old ones and it can be broken into pieces and removed . i tried this as i wont to put in a set of the philips silver bulbs that flash orange .
did you smash the orange lens or did you remove the outer lens? then re stick it?
smashed the orange lens bit with the help from a set of long nose pliers
