205/40/17 what tyre pressure?
Results 1 to 7 of 7
Thread: 205/40/17 what tyre pressure?
    Aug 2002
    UK, Bristol
    MK3 Astra
    Hi,
    Ive got 205/40/17 tyres, does anyone know what the correct tyre pressure should be?
    Thanks
    Matt
    Sep 2001
    Sheffield
    Mk2 Astra Estate
    about 27-30psi, i have 29 at the front and 27 at the back
    MIGClub Member Dave Dempsey's Avatar
    Oct 2000
    Near Edinburgh, Scot
    Vectra C SRi
    Around the 30psi mark, although I run mines at around 32psi
    Couldn't think of anything good to put in here.
    Berkshire
    BMW Beauty
    isnt that the same for every car tyre size?
    Dec 2000
    Gloucester
    3MW B18iS
    Pretty much. Try wacking the fronts higher if you want better steering feel. Like 34psi. 28-32psi at rear. Works for me.
    No, now f*** ***.
    Mar 2002
    the origional cav turbo mannual (not haynes mannual) the manuf mannual states 32 at front and thats with 16 inch
    lee may
    Guest
    I had 26 in the front and 28 in the rear. Good turn in and rear end never steps out.
