How to remove and reinstall rear quarter windows
Results 1 to 4 of 4
Thread: How to remove and reinstall rear quarter windows
    Dec 2009
    Hi all
    I have now 2 corsa B, I know the rear windows are glued in, however the other windows look like they have a rubber band type style holding them in.
    How can I 100% tell there not glued in also whats the easiest method to remove a good window, & reinstall it again.
    Reason I had pro tints on the sides, the car I wrote off on Friday on black ice... So going to swap the windows round, before I scrap the old car..
    Many thanks Wayne
    Jul 2007
    dudley
    mk4 astra estate
    Re: How to remove and reinstall rear quarter windows
    if the 3 door is the same as the 5 the rear quarter glass is also bolted in with plastic nuts, undo these, push the window out then to put it back in use some sealent and bolt it back up
    Dec 2009
    Thanks I take it the nut's are behind the panel...
    I'll take a look in the afternoon it's got to be done... ASAP ...
    Thanks Wayne
    Aug 2008
    Glasgow
    c20xe corsa sport
    there bonded in, all 3 door rear 1/4 windows are
