Fitting a corsa Gsi kit
I am getting all my sideskirts arches cheap as chips but because they have no fixings, where can I get all the bolts/clips to fit the skirts arches etc, is there anything I can use that is just as good?! Thanks!
Re: Fitting a corsa Gsi kit
use that tigerseal stuff and just tap them on in plasce while it drys , heard its good and thats what i will be using to do mine as i have the sri
ok heres what to do- use tigerseal to bond them on but for GOD sake dont put too much on or too little and remember it takes a while to stick so get some masking tape or something on it to hold it in place because you dont want to be sat there holding it all day. But tigerseal is very messy stuff and i cannot stress the importance of making sure u do a clean tidy job first time round because once that stuff is on your paintwork it aint coming back off. good luck
ive got some side skirt clips if you want them as i tigersealed mine on
