Results 1 to 6 of 6
Thread: mk3 astra steering wheel cowel
    Dec 2008
    Lincoln
    Disco 200TDI, CBR400RR
    i've put a calibra steering wheel (non air-bag) on my mk3 which has an air bag standard, problem is, the standard cowel wont fit because the smaller diameter bit of the wheel which should go through the hole in the cowel is to far in (ie closer to the clocks) by about 15mm.
    i reckon this is because the non air bag wheel has the usual pin on a ring and the airbag one has a reel of tape in a little drum instead (4 wires) which spaces it out more
    anyone got any ideas on what i can do? is there a different cowel i can use? it looks like i've nicked it atm so that wont do lol
    [SIGNATURE] [/SIGNATURE]
    MIGClub Member Rusty 16v's Avatar
    Jul 2002
    Pompey
    MK3 2.0 Pineapple
    Re: mk3 astra steering wheel cowel
    Use an Ph1 cowl (ie. from a MK3 with no airbag)
    Check out my sheddy Sport!
    Dec 2008
    Lincoln
    ah cool, didnt kno they did a mk3 w/out air bags. cheers bud
    MIGClub Member J Sabo's Avatar
    Aug 2005
    Cambs, PE15
    Mk4 SRi-T + Van
    i fitted a Momo wheel (no airbag) to an airbag model GSi and the cowl fitted fine?
    New Mk4 SRi C20LET track car in the making.... (slowly!)
    T34, Custom Inlet, Emerald
    Dec 2008
    Lincoln
    i guess the momo boss must have been longer or something? the wheel used to be on my mates corsa which had no air bag and fitted fine. i'll look round the scrappys for a cowel
    Apr 2009
    Lincoln
    Nova SX 1.5 TD
    like i said use a normal none air bag ph1 gsi one!
