Results 1 to 10 of 10
Thread: fibre glass bonnet gen please??
    Oct 2005
    Benn's garage
    hitler's taxi
    hi guys so the time has come to shed some weight on the track car, im planning on having a fully removable bonnet so that its not on hinges when you open it, so thats 4 aero catches in each corner right???
    my main concern is, will the bonnet stay pinned or will it flap about a little???
    MIGClub Member fennyLET's Avatar
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Re: fibre glass bonnet gen please??
    Mine flaps abit but its has stayed on so far lmao
    Oct 2005
    Benn's garage
    hitler's taxi
    Quote Originally Posted by fennyLET View Post
    so yours is a similar setup to how i want to do it??? sounds good if it hasnt come off yet lmao
    Dec 2008
    Lincoln
    Disco 200TDI, CBR400RR
    easiest way is to have 2 pins at the front, and have 2 triangular ali plates over the back corners so the bonnet just hooks under, much quicker to take off then
    i'll try and find a pic...
    [SIGNATURE] [/SIGNATURE]
    Oct 2005
    Benn's garage
    hitler's taxi
    Quote Originally Posted by hay_lewis_68 View Post
    ohh i see what you mean the bonnet "slides" under those plates so you dont have to fiddle with catches
    Dec 2008
    Lincoln
    yeah thats it. my mates step dad had that setup on his nova grasser, worked well i recall
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    what car is this for? depending on the shape of the bonnet you will probably find the centre lifting and cracking to funk at speed, I'd fit a third catch on the front dead centre for security, I was shown an awesome pic of a 205 today with a big /\ in the front of the bonnet at 60mph which on a track is usually cornering speed.
    Oct 2005
    Benn's garage
    hitler's taxi
    Quote Originally Posted by Gaz86 View Post
    hmmm...even if its made with reinforcements?? such as an X bar going through the middle out of say aluminuim rod??? kind of like a support
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    alu rod sounds more promising than a FG brace.
    Oct 2005
    Benn's garage
    hitler's taxi
    its light aswell so maybe make a frame from alu rod/plate, which is an X and then a straight bar going from one bottom point to the other for the front...dunno if that makes sence..?? lol
    im thinking some form of alu plate or maybe even something like stainless/sheet metal which is like 1" wide would be better, it will atleast flex a little bit rather than stay completly solid
