how can i fix this?
how can i fix this??
how much isit likely to cost?
cheers all
Depends how well u get on with your local bodyshop!! guess bout £250ish as need new to remove the naff stuff, weld a new arch on and smoth and paint!
Never fun m8!!
Just clean it up mate, I've seen alot worse than that get through an MOT.
You could always get rid of as much as possible, then fold it in to leave a decent edge. Then a bit of filler, primer and paint to finish it off.
My sisters Cav is worse than yours, but I'm not looking for new arches yet.
If ya need 2 get through an MOT then all ya need to do is put some elephant tape over it. If it aint rough then is should pass!! Try gettin some of that rust kill stuff, slap some on. When finished bit of filler and paint. If U don't want 2 use rust kill stuff U could use a bit of hammerite!! it worked on my m8's car
That will fly through an MOT no problem m8
Dave
If it ain't rotten (yet) I'd get the wet'n'dry and primer out asap...
You're looking at £200 minimum with some places round here charging double that
