Results 1 to 11 of 11
Thread: calibra leather into corsa
    May 2009
    plymouth
    to get fuel
    is this a straight fit? wot would need to be modified?
    cheers
    lee
    May 2009
    plymouth
    to get fuel
    Re: calibra leather into corsa
    cheers fella
    lee
    Aug 2008
    Glasgow
    c20xe corsa sport
    what you have to do is fit the runners from the corsa seats onto the calibra ones, easy job its 4 13mm bolts, remove the 4 bolts and then fit the frames from the corsa on them and bolt back together and they will go straight in
    davie
    May 2009
    plymouth
    to get fuel
    what about the rear sears???
    lee
    MIGClub Member Jamie_Hastings1's Avatar
    Jan 2008
    Sanquhar, United Kingdom
    BMW 320D & CORSA BUILD
    Turbo leather onto corsa foam and backing. Will need stiched.
    Gagging For Boost =(
    May 2009
    plymouth
    to get fuel
    would it be worth while retriming the corsa gsi seats in leather?
    lee
    Sep 2002
    Stockport
    Astra VXR-Cav Turbo
    With abit of patience and screws/cable ties etc.. the backs and the back doorcards will go in!
    Christys Car Hospital - All bodywork undertaken http://www.christyscarhospital.com
    Aug 2008
    Glasgow
    c20xe corsa sport
    what id do is fit the front calibra seats on to the corsa runners and get them fitted, remove the 4 pads from the rear of the tigra and just go and get them trimmed in black leather or leather look material doubt it would cost much
    davie
    Jan 2003
    shropshire
    mk3 gsi astra
    for the rears you use the metal part of the back bench . still use the calibra foam , it wil go onto the corsa metal frame you just have to be patient .
    the bit you sit on can be done 2 ways , take the cali leather off of the cali foam then just spread it over the corsa one ( kinda like a seat cover ) you will need something
    underneath to pull it tight , or the cali rear bench will go in it just sits a bit high but is sooooooooo comphy
    May 2009
    plymouth
    to get fuel
    decided on making it a track car rather than a show car
    but thanks for all the help
    lee
    Sep 2005
    scotland
    one in pic looks well
