Results 1 to 12 of 12
Thread: Wheel Wobble?
    Dec 2008
    Wheel Wobble?
    Happy New Year To All,
    My front wheel/s seem to be wobbling when I get to approx 30mph and I cant figure out what it is.Its more of a wobble than a vibration (balancing)but stops after around 30mph and is fine at higher speeds too,any clues?
    Cheers
    Chris
    Dom
    Dom is offline
    MIGClub Member Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Re: Wheel Wobble?
    1. Are the wheels balanced ?
    2. Are the wheels/tyres round ?
    3. Are your CV joints ok ?
    4. Are your lower arms ok ?
    5. Are your brakes ok or have the discs warped ?
    6. Are your upper mounts ok ?
    7. What kind of car is it ? It might help if you give us some kind of clue
    MIGClub Member angryman's Avatar
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Re: Wheel Wobble?
    Wheel bolts done up?
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Re: Wheel Wobble?
    Oh and the all time classic - are you tyre pressures correct ?
    Dec 2008
    Re: Wheel Wobble?
    i've just put the spare on due to puncture and the wobble is still there,i'll get repaired tomorrow and get balancing checked,but anm little concerned as its just started doing this for no aparrent reason?
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Re: Wheel Wobble?
    Aaaaaaaaaaaand have the rears been balanced? This can give symptoms of front wheel wobble
    Dom
    Dom is offline
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Re: Wheel Wobble?
    Don't rule out wheel bearings either ....
    Dec 2008
    Re: Wheel Wobble?
    I have had wheels off the groung and no play in them at all so im assuming bearings are fine?
    Sep 2008
    Bracknell, Berkshire
    Vauxhall Nova
    Re: Wheel Wobble?
    Sounds like wheel balancing to me, its only about a £5 a wheel.
    Jul 2007
    caerphilly, s.wales
    1.4 16v corsa b sri
    Re: Wheel Wobble?
    i had exact same prob on my corsa, turned out to be a bearing nly cost like 20 quid so its worth getting checked out
    Oct 2005
    Thames Ditton, Surrey
    Corsa Sport 20seh
    Re: Wheel Wobble?
    Maybe the wrong offset wheels. Ive got an unknown make of alloy on my corsa b, got them off a mate. They are the wrong offset and has a bit wobbling sensation in the steering between 60 and 70mph.
    Andy Mac
    Feb 2009
    surrey
    Zaf 1.8 club 2007
    Re: Wheel Wobble?
    do you have a set of generic alloys or factory wheels if they are generic from rsr have you got spigot rings on them i spent a small fortune trying bearings balancing etc in the end took the car to the place i got the whhels and they threw on a set of spigot rings and it sorted the problem out there and then
