Results 1 to 11 of 11
Thread: Removing Mk4 Astra Door Cards?
    Mig Club Member Orange Peel's Avatar
    May 2003
    Nottingham
    I've been asked to fit some speakers into the front doors of a Mk4 Astra.
    I know there are 3 screws along the bottom edge and that its held in by the poppers. Are there any hidden hurdles I have to watch out for?
    Cheers
    MIGWeb Moderator
    Midlands
    Nowt
    Re: Removing Mk4 Astra Door Cards?
    None mate that I know of, good luck
    MIGClub Member tommychimp's Avatar
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    Quote Originally Posted by Orange Peel View Post
    Cheers
    Let us know how you get on, I've got a set to fit to mine, I have a feeling it's similar to a MK3 door, are there screws by the opening handle and the grab handle?
    3.0 V6 CDTI Vectra SRI
    You can't get thicker than a Kwik-fit fitter.
    May 2003
    Nottingham
    I've had it almost off but it seems to be fixed at the top near the mirror. Have removed the plastic near the mirror adjuster but can't see how to get to the thing holding it on!
    Any ideas?
    Nov 2005
    worthing, w/sussex
    Astra "G"
    will have a quick look in the haynes for ya chap.
    I smile because I don't know what's going on.
    May 2003
    Nottingham
    Thanks mate
    Nov 2005
    worthing, w/sussex
    Astra "G"
    only fixings described in haynes are 4 screws, trim clips an the top panel where it hooks over the door frame, you've taken the screws out from the door handle havent you? ( mistake i usually make on fords )
    May 2003
    Nottingham
    I've removed 3 screws along the bottom edge. Not spotted the 4th near the handle. Will go and have another look
    Nov 2005
    worthing, w/sussex
    Astra "G"
    will go have a quick looksee at mine a mo
    Nov 2005
    worthing, w/sussex
    Astra "G"
    just had a look, 2 screws on bottom of door card, then remove leccy windo switch, mirror trim, tweter wire et al, prise off door handle cover and theres 2 screws in there.
    May 2003
    Nottingham
    Thanks alot mate
