Results 1 to 3 of 3
Thread: Lowering 2002 astra van ????Load-sensing proportioning valve
    Dec 2008
    nottingham
    hi, iv got a 2002 astra 1.6 8v van, written on the inside of the passenger door is something about a Load-sensing proportioning valve will this effect anything if i go to lower the van
    is there anything different i need to do or is it just a straight forward spring change??
    Sep 2008
    Auckland, New Zealan
    Chevette XE, Calibra
    Re: Lowering 2002 astra van ????Load-sensing proportioning valve
    Depending on the type - and I assume it works off the suspension/axle - it'll need to be reset and/or bent as otherwise the brakes will operate with too much rear line pressure and cause the rear brakes to lock up under firm/hard braking!
    Aug 2005
    Bradford
    various
    i have mine lowered around 90mm(nova springs) and have never had any issues with rear brakes locking up, or the MOT brake tests.
    This is my ride. There are many like it but this one is mine. Without my ride, I am nothing. Without me, my ride is nothing... Hoorah-Ha
