Corsa B interior Light Change?
Is it possible to change the interior lights?? I currently have the one fitted to sport model has two small lights with the alarm sensor/button in the middle, but want to fit a single large one if possible? i know the connectors are different but if i have the correct wiring that comes with the larger light could i cut/re-wire this to existing wires ??
thanks
