Results 1 to 13 of 13
Thread: how hard?
    Jul 2007
    south yorkshire
    rover 45
    how hard?
    how hard would it be to fit ford recaro seats in my cavalier, with the use of a welder?
    MIGClub Member tommychimp's Avatar
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    Re: how hard?
    depends on the amount of work you need to do and if you need to fabricate brackets etc.
    3.0 V6 CDTI Vectra SRI
    You can't get thicker than a Kwik-fit fitter.
    Dec 2008
    Classified
    Transit mk6
    Re: how hard?
    remove the escort subframes and weld the escort seats to the cav subfames
    Re: how hard?
    If you take the ford subframe off totaly, then you can bolt the seat frame(rail in the bottom) Almost direct to the cav frame. Well this can be done on a nova subframe which are very alike.
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    Re: how hard?
    I thought all recaro seats were the same fundamentally and they only fitted different frames according to the make and model of car they were going into.
    Jul 2007
    south yorkshire
    rover 45
    Re: how hard?
    no these are ford recaro's like what you get in rs turbos
    Re: how hard?
    Quote Originally Posted by tommychimp View Post
    They are all the same. Its the subframes that are different, hence why i said take them off and bolt the seat base to the cav subframe. Thats how i did mine worked perfect.
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    Re: how hard?
    well this is what i did when i swapped my MK2 GTE fronts into the astra as I wanted to retain the seatbelt tensioners.
    Re: how hard?
    Sounds like we did the same thing...
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    Re: how hard?
    Dude thats some spooky shizzle. lmao
    Feb 2008
    eastbourne
    e30 sport,
    Re: how hard?
    i have proton recaro's in my corsa
    bit of jiggery pokery but they look shweet
    Dirrrrty dog!
    Jul 2007
    south yorkshire
    rover 45
    Re: how hard?
    ive ended up gettin a vectra b sri interior cheap, will that got straight into my cav or will i have to take them off runners?
    Re: how hard?
    Quote Originally Posted by breastinspector View Post
    Not by a long shot. You'll be doing the same thing as you would of the recaros.
