Results 1 to 5 of 5
Thread: Paint
    Apr 2008
    hertfordshire
    A Cav
    Paint
    I have a grille i want to paint and it's already painted a different colour. Can someone tell me how to get the best finish. I want to do it with spray cans. I now how rub it down and prime it but im not 100% on how to give it the best finish. thanks.
    Re: Paint
    Red scotch it off, that will key the surface.
    Clean it very well with a degreaser,
    Then you can paint it, if you warmthe paint gently then it will make painting a little easyer,(in the sink with warm water)
    Then laqcuar it after the paint has dryed a little.
    Leave to dry.
    When dry refit.
    Apr 2008
    hertfordshire
    A Cav
    Re: Paint
    thank u. Just curious, i've noticed people talking about flatening? whats that.
    Re: Paint
    You flat lacquar off then polish it up to get a smoother finish, or flat paint off to key it up.(same as scotching it)
    Sep 2005
    norwich
    cavalier gsi 1991
    Re: Paint
    key'ing or flattiening is just basically sanding whatever surface, say smooth paint, so its a little rougher for the new paint to "grip" to. If the surface/paint is perfectly smooth/laqured the paint dont bond to it as well.
