| Re: Corsa Boot Build to make a template of ur floor get a sheet of mdf use ur carpet to mark out the shape n use ajugsaw to cut it out, i always set it on an angle so the top of the wood fits the boot but the botton is cut away alot, allows u to slot it in.
attach a sub n amp were u want.
i would fiberglass the sub into one corner, the amp into the other (where the back lights are, get a bit of wood in the bottom to fit then ur done |
