17-05-2008, 17:55
#1 | | MIGWeb User
Join Date: Aug 2002 Location: Cambridge Drives: '92 Astra GSi C20XE
| wet under carpets?? While removing and sorting out some dodgy audio install today i found out under my front carpets the foam sound deadening was wet. not drenched but wet enough to be more than slight dampness.
Anyone got any ideas where this could be coming in on a phase one Astra Gsi with a sunroof??
Both sides were damp drivers side more |
17-05-2008, 18:06
#2 | | MIGClub Member
Join Date: Aug 2005 Location: Huntingdon/Cambs Drives: Mk3 GSi-T/SportiVan
| Re: wet under carpets?? possible heater matrix, have you lost any coolant from header tank?
__________________ Astra GSiT - 285bhp - 325lb/ft torque |
17-05-2008, 18:21
#3 | | MIGWeb User
| Re: wet under carpets?? forgot to say i did check the coolant level but all seems fine plus it smells more like rainwater than of antifreeze |
17-05-2008, 19:29
#4 | | MIGClub Member
| Re: wet under carpets?? At the back of the bulkhead there is a rubber 'sock' that hands down.
This will be blocked.
__________________ Google has the answer |
17-05-2008, 19:30
#5 | | MIGWeb User
| Re: wet under carpets?? Ta i will have a check tomoz. It's the drain for the scuttle panel you are reffering to? |
14-06-2008, 13:13
#6 | | MIGWeb User
| Re: wet under carpets?? Mine has just been doing this, sorted now |
Members: 43,232
Threads: 310,682
Top Poster: LEE69 (43,151) | | Welcome to our newest member, hayden222 | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
