Trip computer
Hey guys, i was just wondering if its possible to switch between Miles/gallon to Km/litres on the trip computer?? If, so can i switch it back when i wish to??
The rest of the GSIs in my country have their trip comp set in Km/litres. Mines in Miles/gallon. Any ideas?? Also, there is a small letter 'F' in the clock display, what it means??
Any other functions can be done on the trip computer other than the standard (inst cons, outs temp, avg cons and speed, range and stop watch)??
thanks for any tips and suggestions!!
I think there is a chip you can get to convert it over. Not sure where from though. Failing that, you'll have to buy another unit, maybe second hand. It'll work with your existing wiring.
thanks simon, what bout the letter 'f' in the display clock?? any ideas?
The F on the display means that you have a fault in the trip computer system.Is there a mode on the computer that doesnt work. e.g Range,outside temp etc.
