GSi display into Mk3
Will the date/temp/time display unit on the GSi interchange with the standard mk3 unit without any rewiring etc.
Standard unit repleaced by this one http://homepage.ntlworld.com/sulliva...ale/conole.jpg
Cheers
(Hope u don't mind me using your pic Sulli)
nope, sorry m8. lots of wiring involved. its often easier to put a whole loom from a gsi in. lots of sensors and bits to wire in.
Re: GSi display into Mk3
Originally posted by Coppen Will the date/temp/time display unit on the GSi interchange with the standard mk3 unit without any rewiring etc.
No.
almost full rewire from headlights back required as the GSI is basically a mini computer with fek loads of sensors all around the car.
It can be done though, but is alot of hardwork.
Bren did it according to his website. here is a picture.
and even if u wired it all in, most of the functions wouldnt work with ur engine anyways
bugger that then.
It was just a thought as it has a bigger display and would look great with a red led display.
