Help On How To Spray
Results 1 to 9 of 9
Thread: Help On How To Spray
    Jun 2002
    I have bought a front grill but it needs sprayin. felt like a challange any body give me any pointers on how, where and what.
    UK
    Cav turbo and XJR
    Rub it down rearly well.
    Wash off with water and dry.
    Warm up the spray can (should be too much of a problem in this weather)
    Start spraying in the fiddly and hard to get to areas first working out to the nice large bits
    Apply light coats and let dry. DON'T GET CARRIED AWAY saying oh just a bit more here !
    Once finished spraying for a bit, invert can and spray to clean out the nozzle. Otherwise the can will spit on the grill.
    Don't put the grill on newspaper as the wind will blow and bugger the grill paint up. Even if it's a calm day. If I had a penney for everytime.....
    Best to put on wood on the grass.
    Oct 2001
    Herts
    Grale, Mustang, 535i
    Are you just using spray cans, or do you have access to a compressor and gun??
    Mike
    Jun 2002
    I can get my hands on a compressor and gun if it makes the job any easier
    Jan 2002
    West Sussex
    Astra 1.9CDTi 8v
    Make sure you do the coats equally and dont rush otherwise it will end up patchy.
    Oct 2001
    Herts
    It won't make it easier, but you will get a better finish. If you are going to use aerosols try to check to pattern of the spray first (before buying). Some spray in a fan, like a spray gun, which makes it far easier to paint with.
    Wet sand with P1000 (if the grill is already painted), wipe clean with a degreaser, spray on primer, and then depending on instructions on tin, either spray on topcoat when dry, or leave overnight/several hours, wet sand again with P1000 and then topcoat in 2-3 coats.
    Mike
    kent
    alfa 156
    halfords match paint colours to order and come with a wide spray nozzle so you can get a really good finish, use plenty of heat warm the can and the panel up with a hairdryer or heat gun first and it'll shine a lot easier then
    dont buy the paint off the shelf at halfords go to the parts desk and ask them to mix it for you the colour match will be better as well
    May 2001
    52.26320° -0.81374°
    2.0 16v Astra GTE
    Hey, did you know the propelant in the cans is butaine and it will explode if you heat it up too much!
    Veni,Vidi,Scubi
    Oct 2001
    Herts
    As long as it is above about 20 degrees it will be fine. If it is too hot the paint will apply very peely because the solvent will evaporate before the paint can flow out properly.
    Mike
