Hey all trying to fit an astra gte dash in2 calibra. What wire connects 2 what in terms of colour coding? Has anyone done this be4 and could u help me urgently? Thanx
Im 100% perverted, u gotta love it.
I do.
Dash Wire Car Wire Description
All Blacks All Blacks Positive
All Brown All Brown Negative
Blue Blue Temp gauge
Green Green Rev counter/ tachometer
White White Full beam blue dash light
White with Yellow Grey with Green Sidelight green dash light
Brown with Yellow IGNORE
Brown with Blue Brown with Blue ECU dash light
Brown with White Brown with White Handbrake dash light
Grey with Green IGNORE
Blue with White Blue with White Battery dash light
Blue with Black Blue with Black Petrol/ Fuel gauge
Black with White Black with White (Steer Col) Right Indicator dash bulb
Black with Green Black with Green (Steer Col) Left Indicator dash bulb
Blue with Yellow IGNORE
Blue with Green Blue with Green Oil Pressure gauge
Wires from Transducer LCD Dash
Black Blacks from car loom Positive
Brown Browns from car loom Negative
Blue with Red Blue with Red Speedometer
IF THIS DOESNT COME OUT PROPERLY AND YOU DONT UNDERSTAND IT THEN CONTACT ME!!! AND I WILL SEND YOU THE WORD DOCUMENT!
Dash Wire----------------Car Wire ------------Description
All Blacks -----------------All Blacks -----------Positive
All Brown ----------------All Brown ------------Negative
Blue ----------------------Blue ------------------Temp gauge
Green --------------------Green ----------------Rev counter/ tachometer
White --------------------White -----------------Full beam blue dash light
White with Yellow------Grey with Green----Sidelight green dash light
Brown with Yellow -----------------------------IGNORE
Brown with Blue --------Brown with Blue----ECU dash light
Brown with White------ Brown with White- Handbrake dash light
Grey with Green--------------------------------- IGNORE
Blue with White--------- Blue with White---- Battery dash light
Blue with Black ----------Blue with Black -----Petrol/ Fuel gauge
Black with White --------Black with White--- (Steer Col) Right Indicator dash bulb
Black with Green -------Black with Green---- (Steer Col) Left Indicator dash bulb
Blue with Yellow ----------------------------------IGNORE
Blue with Green -------Blue with Green------ Oil Pressure gauge
Black --------------------Blacks from car loom ----Positive
Brown ------------------Browns from car loom ---Negative
Blue with Red ----------Blue with Red-------------Speedometer
ANY BETTER????
