Results 1 to 6 of 6
Thread: how much to lower car by?
    Mar 2008
    birmingham
    BMW 318is
    i was so close to buy some springs and shocks for my corsa they were Front:60mm Back:40mm but i backed out. i want it too be quite low but avoid rubbing any ideas??
    Apr 2002
    Southwest
    Like its stolen
    Re: how much to lower car by?
    60/40 isnt bad on a corsa IMHO
    MIGClub Member Fow16v's Avatar
    Feb 2006
    Pontypool, S.Wales
    Mk4 GSi Van
    defiantly 60 on the rear, and either 40 or 60 on the front, as chip said 60 aint that bad on a corsa
    Mar 2008
    birmingham
    BMW 318is
    would there be any rubbing tho? as there always is one person int the back and my subs weight lowers the bk aswell.
    Feb 2006
    Pontypool, S.Wales
    Mk4 GSi Van
    with those wheels you should be fine as they are the correct offset, if they do rub tho just remove the 2 top bolts from the arch trim and it will be fine then. mine is lowered 60 rear with 7" rims and there is no rubbing with the bolts removed
    Jun 2005
    Gatwick
    Clio 182
    I would go -40mm personally
