Results 1 to 6 of 6
Thread: would a 5x112 pcd wheel fit our 5x110 pcd?
    May 2004
    newcastle upon tyne
    cars fast
    someone told me you can get away with about 2 mm but i cant see it lining up properly tbh.
    been offered some wheels which are from a caddliac which has a pcd of 5x112 and was thinking of fitting them to the cav which is obviously 5x110 will it or wont it
    www.vauxsausage.com - the place for all your vauxhall buying/selling needs
    Jan 2007
    Co. Meath, Ireland
    Kadett E V6
    Re: would a 5x112 pcd wheel fit our 5x110 pcd?
    Youd probably get away with it using wobbely wheel bolts
    Jul 2006
    wigan
    also you have to make sure the bore size is bigger than 65.1 and also the right offset no less than 35 et other wise they will rub
    EY
    EY is offline
    MIGClub Member EY's Avatar
    Feb 2006
    Wymondham, Norfolk.
    to get more petrol.
    I wouldn't.
    MIG Performance camping
    1993 phase 3.5 Calibra turbo.
    MSG
    MSG is offline
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    use a spigot ring so the rim centres on the hub properly and then tighten bolts evenly a bit at a time and then fully tighten them to max torque.
    MIGClub Member angryman's Avatar
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Quote Originally Posted by heds View Post
    They will fit with wobble bolts
    Long thread warning
