Results 1 to 7 of 7
Thread: gas struts on mk3 astra ?
    Feb 2002
    Uk
    bonnet gas strut ifters on mk3 astra ?
    any1 know which to use and how to fit em???
    WWW.XenonShop.co.uk - Specialists In HID Car Lighting Systems
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    All Facelifts were Gas were they not?
    Replaced the wife's with Centaur (Kwik fit) lifetime Guranteed Gas ones (Wish I'd put Konis on but she wouldn't let me)
    Rears just top nut and bottom bolt.
    Fronts require strut taking off and Springs removing (specialist tools)
    Feb 2002
    Uk
    sorry how dumb of me i meant bonnet gas lifters?
    Aug 2000
    Near Peterborough :(
    STR10K & STR1K
    Assuming the Mk3 astra ones are the same as Cavalier etc. Usually you remove the top bolt from the bonnet hinge, then one from the wing top, then just click the strut into place with the ball joint fittings. Fitting usually takes under 10 mins.
    Daddy Cool
    Drive a Bertone edition Vauxhall? Check out www.vboc.co.uk
    Feb 2002
    Uk
    so can i get some struts from a scrappy if so which 1`s do i use?
    Aug 2000
    STR10K & STR1K
    Oh, if you are looking at converting some you may have to use brackets etc.
    You can buy them ready to fit complete with fittings for Astras tho. Wouldnt bother with scrappy for them tbh.
    Usually about £40 for a pair.
    Daddy Cool
    Dec 2001
    Chelmsford, Essex,
    Gavin Wallace does em, (top of page)
    PVD do them, many other places too
    CAv ones cost £35 from Gav.
