Cav GSi black boot panel
Results 1 to 5 of 5
Thread: Cav GSi black boot panel
    Aug 2001
    Penryn, Cornwall
    BMW 318iS E36
    Does anyone know if this fits the hatchback aswell?
    Ta,
    UK
    Cav turbo and XJR
    black panels are available for hatchbacks off GL & CD models.
    In answer to your question. A hatch will fit a saloon but a saloon will not fit a hatch. Trouble is i'm not sure which way round it is.
    They are not the same anyway.
    Sorry.
    Joy
    Joy is offline
    Sep 2001
    Devon
    2WD Cav Turbo
    Yep, it`ll fit your hatch mate
    3.0 V6 Mk3 Cav - Saab B308I, F28, Speedlines, Wilwoods
    Cav 16v Turbo - T34, water inj, 26psi, F28, LSD, Speedlines
    04 Monaro 5.7 CV8 - Pedders Suspension, Wortec Catback
    Jan 2002
    Nr. Ipswich, Suffolk
    Transit Connect & Cav GSi
    I assume that its going to be the same problem as fitting Turbo centre reflector panel to a hatch, on the facelift shape.
    If it is, than no they don't fit (very well anyway). The problem is that a hatch has a painted strip under the lights and the saloon doesn't. This means that the saloon panel has a lip on the bottom curving inwards and the hatch one doesn't. It curves out slightly at the bottom.
    Mar 2002
    Hatch panel will fit a saloon but saloon panel won't fit a hatch. The hatch panel tapers at the bottom where the saloon panel is straight.
