Can anyone tell me where the best place to get 195/40 16" Tyres from is?? Its a pretty unpopular size, and I'm struggling to find them at a resonable price.
Anyone on here got them? If so, what type and how much were they/were'd you get them?
Cheers![]()
Cheers![]()
Check out -www.justopelvauxhall.com
Carb'd, XE'd Nova - 187bhp.
Mytyres.co.uk
Only Continental & Dunlop make that size IIRC Maybe another brand recently.
(edit) your Car looks fab in this months TV btw Chris.
For the extra cost over a 45 I really cant see the point. MAkes for a harsh ride & that much more susceptable to damage or blowouts etc.
not really any extra cost, seeing as how cheap mytyre is and they will all but stop any rubbing
i got 2 195/40/16 toyo proxes t1r tyres fitted balanced with new valves for £130 at my local tyre place. thought that was a good price really
EDIT: realised i put 195/45 when i meant 195/40
Toyo do a 195/40 R16, I have them on my Nova, £50 each or so from www.camskill.co.uk.
I took on board what you said and very nearly rear disc'd it over the winter, with moving the stub axel's in over as part of the conversion, but money simply won't allow at the moment. I need four new tyres anyway, so think going to a lower profile will help for now without having to change anything else.
Anyone fancy donating a modded rear axellmao
I cant understand why its rubbing. Your wheels et 49?
Try Yoko A539 in 45 profile, they are very slim size wise (make other 45's look huge). Cheap too.
Hi, hope this helps... i have a Nova saloon... so the rear inner arch will be different, currently have 60mm drop and 16" Speedline Alesio 2 ET49 with p zero 195x45x16 tyres
i failed the MOT as they rubbed on the inner arch, if i had any thing in the back, i added 10mm spaces but now if any body gets in the back they rub on the outer arch...
when i bought the tyres kwikfit said 195x45x16 would be the correct rr but after a bit of checking its increase by 20mm 195x40x16 would have been spot on for my original 145x80x13 tyres.
found these on ebay 4x Toyo T1R 195/40/16 Tyres £215 + £18 P+P but then you got to get them fitted... don't know if there any good but hope it helps..
No mate, 44-46mm ish, probably 45, lol! Rough measurment I took a while back!!
Hmm, brt they'd be a bitch to fit tho, pirelli's are rock hard!!
Cheers, I've found them for £213.53 delivered from mytyres.co.uk - fitting isn't a problem, I can do it myself at work!
I don't have any worries for the MOT, its only when I have a passenger and a boot full of camping/cleaning gear and tools on my way to shows that it rubs really bad!
Think the credit cards gonna be getting a hammering soon, need them before I put it back on the road in a month or so's time!
i say p-zeros they are the answer to all arch problems !
click here 2 c my old nova
new WIP nova c16xe will get pics up soon
