Results 1 to 5 of 5
Thread: how to take out seats
    Dec 2007
    Ireland
    Nova GSi
    a how to on taking out the seats front and back
    Jesse
    Mar 2007
    hertfordshire
    c20xe & let cav's
    Rolleyes
    with a spanner and abit of elbow grease. that should do the trick !! lmao lmao
    Dec 2007
    Ireland
    Nova GSi
    how many nuts??
    Nov 2005
    worthing, w/sussex
    Astra "G"
    i've got two thanks lmao lmao
    there are usaully 4 nuts/bolts holding the front seat down, 2 front and 2 rear of the s/frame, rears iirc just lift the lower section from the rear of the seat and dis-engage the wire loops at the front, rear back iirc is bolted to either side and on the hinge plate (if its a split rear seat that is)
    I smile because I don't know what's going on.
    If its a nova as in your drives< then its 2 13mms at the front, life the flap in the carpet and you'll see them, undo them both and then slide the seat back as you do it will slide back and off the floor runner.
    Subframe off, as above^ then there are 2 13mms at the front of the seat on the inside part, and two 10mms on the rear at each side.
