11-01-2008, 13:52
#1 | | MIGWeb User
| polished alloy laquared does anyone have any pics of polished alloy engine parts that have been laquared ie-: cam covers etc?
__________________ EURO STYLE RULES |
11-01-2008, 14:20
#2 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
| dulls the finish, no one does it unless its a varnish type, water based rots the finish too. |
11-01-2008, 15:02
#3 | | MIGWeb User
| if thats the case wots the best thing to prevent oxidizaition on polished parts during sh@tty wet/winter months? |
11-01-2008, 16:38
#4 | | MIGWeb User
Join Date: Mar 2004 Location: North Wales Drives: Astra Mk3 / Golf GTI
| you can get protective waxes that you can apply but i'd imagine that they'd need to be re-applied regularly.
There are special laquers that are designed to go on polished metal (IIRC Frost sells some) but i've never used it so i can't comment on the reliability etc.
__________________ Astra Progress =[IIIIIIIIIIIIIIIII--] Suspension Refurb :| Golf Progress =[IIIIIIIIII------] Daily Driver :) |
11-01-2008, 19:03
#5 | | Regional Co-ordinator
| You can get a lacquar thats used to polished ally and brass, its what my wheels will be done with.
Normal lacquar will dull the finish down, but if its not hugely seen you'll get away with it.
__________________ Quote: |
11-01-2008, 19:08
#6 | | Regional Co-ordinator
| Polished then halfords rattle can lacquared,
You can see the mister look...(not to two bit pics i know..)  |
11-01-2008, 19:27
#7 | | MIGWeb User
| dont look too bad IME it always fogs |
11-01-2008, 19:41
#8 | | Regional Co-ordinator
| Its still wet ish there, looks duller now its dryed. Is gonna be sanded and re polished then done when my wheels are. |
11-01-2008, 20:12
#9 | | MIGWeb User
Join Date: Oct 2000 Location: Bristol Drives: 300ZX TT & Seat Leon
| Wouldn't lacquer polished alloy at all. Can do more harm than good. Because polished alloy is as it sounds, it isn't keyed, so when you apply lacquer to polished metal, it never bonds to it. This means that water is free to leach between the two surfaces and doesn't dry off. You'll introduce corrosion at a quick rate. All you need too is the minutest of chips on a paint that's not actually bonded to the metal (which is easy to do) and the thing just spider webs between the surfaces and it will naturally anyway regardless of whether there are paint particles missing.
You're better off using something like metal mate sealant. http://www.clean-image.co.uk/paintse...protection.htm |
12-01-2008, 03:32
#10 | | MIGWeb User
| i wouldnt lacquer polished alloy either, i had a nice set of polished RS2000 wheels on my escort estate and as Simon says they very very quickly became corroded. These had been done by a proper alloy wheel refurbishment place as well, not just a home job. Worst bit of all is i now have to strip all the lacquer to try and polish the wheels again to sell them. |
12-01-2008, 09:38
#11 | | Regional Co-ordinator
| Quote:
Originally Posted by SimonP | I have 3 cans of the supawheels by Supagard, i didnt know it would look after poilshed rims. |
12-01-2008, 11:09
#12 | | MIGWeb User
| Why wouldn't it? Metal is metal, doesn't matter whether it's a wheel or a nugget.
I haven't used metal mate on my rims as it never lives outside or gets driven in the winter/rain. The only time the rims get wet is when I wash it. Once a month they given given a quick rub down with Autosol then I use Brilliant polish on top to get rid of any swirls and fine markings.  |
12-01-2008, 21:02
#13 | | MIGWeb User
| supawheels is good for keeping crap off wheels doesnt really do much in the way of water, the only benefit would be the fact the waters beads off them better |
Members: 43,232
Threads: 310,682
Top Poster: LEE69 (43,151) | | Welcome to our newest member, hayden222 | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
